ok new setup whats it going to run
mustangrfast88
330
middletown ohio
ok guys here is the setup for this year on my car what you guys think it will run
1988 ex 4 cyl car hatchback
engine is a 302 bored .030 over to make it a 306
stock crank turned 10/10
stock rods with arp bolts
keith black 11.1 to 1 hypertonic pistions
afm n111 camshaft
victor jr heads 2.05 and 1.60 valves
victor jr intake
edelbrock 750 carb
transmission
tremec tko
afm flywheel
afm hi rev clutch
tremec bellhousing
alum driveshaft
pro 5.0 shifter
rearend
8.8 stock mustang rearend with 4.30 gears eaton posi
tires
28x8.5x15 micky tompson et streets and true slicks
ignigtion
all crane ignition system
sorry so long just wanting to knwo what you guys think this setup will run
I could be way off, but what does the car weigh? If stock or near it, I don't see 11's. The thing should be stout, but I don't think enough to break into the 11 sec range.
the weight i did all my times and mph on the car weighted 3350 but i am sure i can get it way down below that i am thinking more like race weight of 3050 so if i am making 400 horsepower at the rear wheels and the car weights 3350 it will got a 11.85 @115 but if i get the weight down to 3050 it should go a 11.46 @ 119mph so the weight should be righht around 3050
