  • SN95 4.6L Mustang Tech
OK one more question
  • Thread starter Thread starter Texstang9682
  • Start date Start date Apr 1, 2009
Texstang9682
115
Austin, Texas
Apr 1, 2009
  • Apr 1, 2009
My speedometer has recently given up the ghost. And also my odometer has called it quits a few months ago.
I have checked under the car to see if the speedo gear is still in place and it is.
However I was messing around under the driver side dash running some speaker wire maybe could I have pulled it away from the gauge cluster in the back.
And as for the Odometer not working it dosent bother me cause my car still has 88K on it when it really has about 94K. But what do yall think may have caused the malfunction. Thoughts?
Thanks, CLINT
squeak93
2,341
414
164
Joplin, Missouri
Apr 1, 2009
  • Apr 1, 2009
There is a sensor on the trans the will cause the odometer to stop. Check that first for loose wires and such. Its a wierd set up.
RedDaemon
3,470
9
108
Atlanta, GA
Apr 1, 2009
  • Apr 1, 2009
if the odometer goes blank does that mean for the time its out it is not counting new mileage?
so. if yours goes out and you drive 5 miles and it comes back on..wit the odometer read correctly?
evil281
276
Arizona
Apr 1, 2009
  • Apr 1, 2009
its possible the display itself is just broken and it is still racking up milage, im sure it couldnt be that easy just to disconnect the right wire behind the cluster to stop your milage from adding up, there has go to be some security so people dont fudge with he milage
Posted via Mobile Device
LRSjmac
Premium Sponsor
Sep 9, 2008
335
Hewitt, Tx
Apr 1, 2009
  • Apr 1, 2009
It sounds like you have 2 seperate issues at play. If the odometer quit working first & the speedo continued to work (on 94-98 cars only), the likely culprit is the odometer drive gears. The speedometer can be any of the following:
wiring/bad connection
speed sensor
drive or driven gears in the transmission
speedo head gone bad
RedDaemon
3,470
9
108
Atlanta, GA
Apr 1, 2009
  • Apr 1, 2009
im not sure about the OP but in my particular situation-> When i first get into the car and turn it on, the odometer initially works (it flashes all 8's) and then shows the mileage. then once i am driving itll just quit out. it does randomly come back.
im going to assume this is a wiring problem.
ive taken the cluster out of the dash before and i dont recall many wires leading to it. will i have to open the cluster to fix my problem? or is it likely to be in the wiring harness leading to it?
LRSjmac
Premium Sponsor
Sep 9, 2008
335
Hewitt, Tx
Apr 1, 2009
  • Apr 1, 2009
Sounds like your issue could either be a bad cluster or a wiring/connection issue between the cluster & PCM.
evil281
276
Arizona
Apr 1, 2009
  • Apr 1, 2009
my money is on bad wireing, check the wireing directly into the plug and make sure noneof the prongs are bent
Texstang9682
115
Austin, Texas
Apr 1, 2009
  • Apr 1, 2009
well the trip odometer still works, but the over all cumlation count is not moving since it said 80K or so miles
RedDaemon
3,470
9
108
Atlanta, GA
Apr 1, 2009
#10
  • Apr 1, 2009
  • #10
thanks guys. the next time its a nice day out ill give it a look and see what i can find
fasthippo
52
OC, CA
Apr 2, 2009
#11
  • Apr 2, 2009
  • #11
my speedo and odometer gave up on me a little while after the head swap on the saleen and it ended up being the part of the wire loom around the back of the engine. the egr pipe had melted through a couple wires and shorted it out. i dont know if your problem is the same but maybe it'll give you somewhere to start looking i hate wiring.
good luck
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
Run a 5 channel or use head unit and mono amp for sub?
  • 2000xp8
  • Sep 20, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 23, 2024
2000xp8
W
Blue smoke..
  • Wicked_Rpm
  • Aug 11, 2024
1996 - 2004 SN95 Mustang -General/Talk- Aug 14, 2024
weendoggy
SN95 Instrument Cluster Knowledge Search
  • Bee
  • Feb 24, 2023
2K
SN95 4.6L Mustang Tech Feb 28, 2023
Mustang5L5
M
  • mnky99
  • Sep 5, 2025
mnky99
M
