Hey guys, I finally got behind the intake and pulled the PCV Screen, when I pulled the rubber hose off. There was no PCV valve to be found, so I went ahead and pulled the screen. I wiped it off with a rag as you can see in the pic, but it had a ton of oil in it. I also used the air compressor to blow it out and a lot of oil came out of it. When I put the air to it I couldnt feel the air on either side. There was a lot of oil comming out behind the intake, was this the culprit? So im going to buy a new screen, gromet, and Turbocoupe PCV valve. Also going to buy a check valve for it. Tell me what you think, aslo I want to know if you feel this was the reason oil was comming out back there. Thanks
Dave
Dave
It would stumble off the line, etc.
