Ok stangnet need help again
  • Thread starter Thread starter RoadKill96
  • Start date Start date Apr 20, 2007
RoadKill96
39
Victorville CA
Apr 20, 2007
  • Apr 20, 2007
I must have a brain fart or im just to darn tired my first question is why would my car die out as in everything shut's off while im driveing on the freeway it came back on after 10 sec's. Second question what in the world is a feedback control solenoid and where is it on my 90 5.0 LX. Third question why does my car run better at lower elevation and what sensor can i fix so it wont do that anymore?? thanks alot guys and jrichker thanks cause i know you will help on this one
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 20, 2007
  • Apr 20, 2007
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
RoadKill96
39
Victorville CA
Apr 20, 2007
  • Apr 20, 2007
Thanks J ill have to do it in the morning
dragnazz5.0
My "0" key d0esn't w0rk, s0 I have t0 use the zer0
Nov 19, 2005
815
mooresville, nc
Apr 20, 2007
  • Apr 20, 2007
the feedback control solenoid is either something in the smog pump system or the egr system. map sensor will cause the car to run weird at different elevations
Engine (Help needed) Engine will only idle with incorrect vacuum routing, huge surging idle when routed correct?
  • deserthoundLX
  • Apr 14, 2024
2K
Fox 5.0 Mustang Tech Jun 25, 2024
CAMTWO1070
Engine Throwing codes 94, 33, 34, 44, and sporadic engine shutoff.
  • Ryu
  • Oct 9, 2024
Fox 5.0 Mustang Tech Sep 13, 2026
R
Progress Thread Need help
  • rockyracoon
  • Nov 24, 2022
1996 - 2004 SN95 Mustang -General/Talk- Dec 1, 2022
COramprat
New daily driver help needed.....not a mustang but mustang drivetrain.
  • Wayne Waldrep
  • Jun 17, 2024
  • Other Auto Tech
  • 3 4 5
7K
Other Auto Tech Jul 28, 2024
manicmechanic007
A
Electrical Help Me, Help My Fox ! 1990 Wiring Assistance please ?
  • Anewjer00
  • Jan 8, 2022
2K
Fox 5.0 Mustang Tech Jan 8, 2022
evintho
