  • SN95 4.6L Mustang Tech
? on pi intake
  • Thread starter Thread starter pnyxprs96
  • Start date Start date Oct 26, 2008
P
pnyxprs96
10
  • Oct 26, 2008
so i was wanting to know what all is required to put the pi cams and pi intake on non pi heads and is it worth it since im not goin to replace the heads untill i get my new motor built (which might take awhile)
02nightmaregt
To hell with your Mustang, I want to see your HOG!
Jul 1, 2007
513
Southern Indiana
Oct 26, 2008
  • Oct 26, 2008
Not sure whats all involved other than the intake and cams(being as how im already PI), but yes its worth it. I'm sure others on here that were NPI that are now pi will tell you the same. Best bang for the buck
98COBRA281
1,348
30
59
Port St. Lucie, Florida
Oct 26, 2008
  • Oct 26, 2008
for the cams you will need pi cams bolts, and for the intake you will need a pi coolant tube, (the tube that runs under the intake manifold) or you could just use a rubber hose, and clamp it to the water pump nipple...
Big Show 96
81
Louisiana
Oct 26, 2008
  • Oct 26, 2008
I don't know much about the cam install besides that the cam girdles break easily. Make sure you unbolt them evenly. I installed the PI intake on my 96 GT with little mods. I swapped the front cross over tube so that I would not need to drill & tap for the temp sensor. I also used the PI gaskets to mount the intake to the heads. You will need to apply a little red RTV around the water coolant ports. They are shaped a little different & the RTV is just for extra precaution. (Mine sealed fine)I tried the rubber hose under the intake & it didn't work well. The PI intake is deeper & close to the water pump causing you to make a hard 90 degree bend crimping the heater hose. ( USE THE PI COOLANT TUBE!!!) You will also need to change the water pump nipple from the 96 to 99-04 water pump. With this intake you will find the rev limiter a little faster. ( Good upgrade for non PI motor ) Go to americanmuscle.com & there is a step by step article with pictures for this install.
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
D
4.6L 4 valve Sleeve
  • DangStitches
  • Oct 10, 2026
DangStitches
D
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Tuesday at 2:05 PM
Kleinjj27
K
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
I
Engine Insane fuel trims +25% LTFT Bank 1, -16% LTFT Bank 2
  • imw_stl
  • Aug 31, 2025
SN95 4.6L Mustang Tech Sep 19, 2025
Mustang5L5
