Hello all, I have been trying to figure this boost problem out for a year now... I have the on 3 performance 76m turbo kit and I am only making 8 lbs of boost with springs set for 18+... I have removed and blocked the wastegate and still no extra boost. I did a boost leak test and only found minor vacuum leaks and fixed them. Also performed a cylinder leak down test and all numbers came back great. Fixed the minor exhaust leak I had and still no more boost. The turbo seems to only be making 8 lbs no matter what. There is no boost spiking or lag with the turbo, no shaft play or any problems with the turbo to make me think it would be the turbo itself.... I even pulled the turbo off and inspected inside the turbine housing to make sure nothing was jammed in there, like i've seen from some other posts on here. Any ideas on what could be the problem!?
My setup includes:
363 sbf built by TREperformance
ebay aluminum heads
comp cam -NX274HR
76mm on 3 turbo kit
ran through a C4 with transbrake and custom torque converter built for ~1000hp.
My setup includes:
ebay aluminum heads
comp cam -NX274HR
76mm on 3 turbo kit
ty parts across the board, but you get what you pay for. If you're using the BS On3 wastegate, get rid of it. If it's not your problem now, it will be, eventually. Then you'll have a shortblock problem, too. I admit my bias towards the company. They put other good companies with quality products out of business, had extremely shoddy customer support refusing to stand behind products with obvious and common defects, & of course they source to the cheapest bidder, which ended up being the Chinese. They are a volume company, and it's hard to look past a turbo kit for less than half the price of a quality one, but I will personally never do business with them, despite the temptation. If any of these comments are no longer true, then at least that's where they came from.
