  • 1994 - 1995 Specific Tech
One more Explorer intake thread
  • Thread starter Thread starter Blackrosepet
  • Start date Start date Jul 31, 2010
Blackrosepet
55
  • Jul 31, 2010
And yes, I searched, but the 8 pages of info made my head hurt.
Explorer intake on a 94 GT, do I need the non-egr or the intake with the egr holes. Or will either one work? I'll be keeping the stock TB.
-amanda
blksn955.o
3,263
st.louis mo 314
Jul 31, 2010
  • Jul 31, 2010
either will work with our stock t-body and the elbow to make the stock t-body work.
You will only want the internal EGR passages if you plan to keep the EGR and swap to a fox t-body setup.
If it has the internal ports and you use the elbow this will block these internal passages making it function as an external intake.
Blackrosepet
55
  • Jul 31, 2010
That's what I was thinking, either intake will work if I use the stock Tb with the elbow adapter. I just read all 8 pages of threads earlier and I probably confused myself and felt like this o.O.
Thanks!
blksn955.o
3,263
st.louis mo 314
Jul 31, 2010
  • Jul 31, 2010
I would say look for an internal that way if you ever down the road want to convert to the fox t-body and want to keep the EGR you can.
People often want to delete the EGR but really there is not a big reason to do this. The EGR is off at WOT, helps with MPG, and unless the system is totally busted its just not worth it IMHO as you will want to tune the EGR off as it will generally cause a mid load knock. There is a slight bit of added heat you could argue that heats the intake/heat soak but really with an alum intake its going to heat soak anyway.
Blackrosepet
55
  • Jul 31, 2010
I'm just going to keep the sn95 tb. The car is just a daily driver with a leaking lower intake gasket. Since the intake will be off anyway and I'm finding good deals for Explorer intakes on ebay, I figured why not.
Engine Catch Can or not?
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 6, 2026
ctandc
C
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
