One quick question
  • Thread starter Thread starter grey5.0beast
  • Start date Start date Nov 20, 2006
grey5.0beast
Cookies should never be DUNKED!!!
Aug 3, 2004
atl ga
Nov 20, 2006
  • Nov 20, 2006
On the starter solenoid, which one is the "S" wire? I am testing my TFI and have gotten down to that step, using these directions(see below) Thanks
Make sure that 12 volt power is available to the TFI connector at the correct terminals with the switch in "RUN" and "START".
Disconnect the EEC computer.
Disconnect the connector to the TFI module on the distributor.
Unplug the fuel pump relay
Disconnect the "S" wire at the starter solenoid
Disconnect the connector at the coil
Hold the TFI connector so that the terminals face out with the locking tab to the right.
The connector pins are referred to as #1 at the bottom up to #6 at the top.
Insert a straight pin into the terminal being probed.
Use a VOM to check for +12 volts on pin #3 with the ignition switch in "RUN"
Use a VOM to check for +12 volts on pins #3 and #4 with the ignition switch in "START"
Use a VOM to check for +12 volts on the red/green wire at the ignition coil in "RUN" and "START" If OK, reconnect all connectors except EEC and fuel pump
Use a VOM to check for +12 volts on the red wire at the TAD and TAB solenoids, EVR, Canister Purge Solenoid, and at the Idle Speed Air Bypass Valve in the "RUN" position
Turn ignition switch to "OFF"
grey5.0beast
Aug 3, 2004
atl ga
Nov 20, 2006
  • Nov 20, 2006
ttt
HISSIN50
34
129
Nov 20, 2006
  • Nov 20, 2006
It should be the little wire on the slide-on terminal at the top of the solenoid.
grey5.0beast
Aug 3, 2004
atl ga
Nov 20, 2006
  • Nov 20, 2006
k thats what I was thinking thanks. I'll let you guys know how testing goes, and let's HOPE its a bad tfi so I can get over these problems w/ no more headaches!!!!!!!!!!
grey5.0beast
Aug 3, 2004
atl ga
Nov 20, 2006
  • Nov 20, 2006
Ok well I haven't finished testing everything yet, as I didnot know what a EVR was, but now I know it controls the opening and closing of the EGR, via the TFI. The Tfi also controls the fuel pump turning off, and these problems are simultaneous, IT HAS TO BE THE TFI!!! Yay, I think I can get my car running, I haven't drv ien it in a lil over a month, damn I am excited!!!
grey5.0beast
Aug 3, 2004
atl ga
Nov 20, 2006
  • Nov 20, 2006
Well it says I am getting power to the EVR, but where is the TAD and TAB, are they the valves on the smog pump's lines? There are no power wires going o them, only vacuum lines. and WTF is a canister purge solenoid? and where is it?
one more Q, what relay is directly under the MAF on the wall? It is buzzing loudly and I want to know if it is contributing.
795.0pacecar
lover of pudgy polygamists
Jul 11, 2003
480
Senoia, GA
Nov 20, 2006
  • Nov 20, 2006
I have a spare TFI module if you want it. There should be wires going to the TAD TAB solenioids, and the canister purge valve is was releases fuel vapors from the carbon canister into the intake.
grey5.0beast
Aug 3, 2004
atl ga
Nov 20, 2006
  • Nov 20, 2006
hellyeah, How much are they, if they are not too much I'll go buy one. I can't find em on any parts places' websites. If not I'll give you a call tomorrow and come pick it up, I GOTTA get this thing running b4 Sat.
795.0pacecar
Jul 11, 2003
480
Senoia, GA
Nov 20, 2006
  • Nov 20, 2006
They are about 45-60 bucks depending on whether or not its a cheap parts store replacement or not. My spare is actually a somewhat expensive Accel unit.
grey5.0beast
Aug 3, 2004
atl ga
Nov 20, 2006
#10
  • Nov 20, 2006
  • #10
I can't come by tomorrow, I gotta work, but how's wednesday?
795.0pacecar
Jul 11, 2003
480
Senoia, GA
Nov 20, 2006
#11
  • Nov 20, 2006
  • #11
I get off work at 6:30pm on Wednesday so anytime after that is cool with me.
HISSIN50
34
129
Nov 21, 2006
#12
  • Nov 21, 2006
  • #12
EVR = EGR vacuum regulator.
TAB/TAD: Thermactor Air Bypass/Diverter.
Under the MAF is the WOT relay. If it makes an annoying sound, try moving the relay and it's wiring. The wires vulcanize and you get get a nice buzz from them as things are shorting or malfunctioning. This should not be affecting your issue, unless your AC compressor isnt staying engaged.
Parts stores can test a TFI if needed. Otherwise, it's nice that you got a bud here to help out.
grey5.0beast
Aug 3, 2004
atl ga
Nov 21, 2006
#13
  • Nov 21, 2006
  • #13
Well I am getting a HIGH tps volatge at WOT under my mem. codes, so that relay could be that problem. Then I will replace the TFI and see if that finishes it off. Thanks for all the help
grey5.0beast
Aug 3, 2004
atl ga
Nov 21, 2006
#14
  • Nov 21, 2006
  • #14
Well I wouldn't get there till probably 9, I get on work at 4 wed. and off at 8, so if thats cool, I can leave directly from work. I will go to a parts store first for them to test my tfi tomorrow mornin then I'll let you know, and if its bad and its cool w/ you that I come that late then I can make the trip. Thanks alot man!
HISSIN50
34
129
Nov 21, 2006
#15
  • Nov 21, 2006
  • #15
I'm not aware of a code for TPS being high at WOT. If WOT voltage is 4.5-5.0 volts, it should be alright.
Good luck with it.
Dean85GT
502
Thorold, Ontario, Canada
Nov 21, 2006
#16
  • Nov 21, 2006
  • #16
Offtopic but did you get that blower on your car?
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
