one time use bolts
  • Thread starter Thread starter Konrad
  • Start date Start date Aug 4, 2011
K
Konrad
27
  • Aug 4, 2011
What is the technical reason for one time use bolts? How does work and why is it so important.
I installed BMR LCAs and my understanding is that some of those bolts are one time use. I didn't have bolts and didn't have time to go get them so I put the old ones back in. How big a deal is that?
I've got noises back there but everything feels tight.
mbuckcoyote
86
Portand, Or.
Aug 4, 2011
  • Aug 4, 2011
Torque charactoristics of bolts change from use. When torqued down, they stretch. When loosened the do not retract, therefore becoming weaker on second use. The use of torque angles suggest that replacement is necessary as well but, that's not something attributed to LCA's.
However, IMO, if you use the same bolts and don't overtorque, you should be fine. The only time I might discard old for new is on heads, exhaust manifolds, flywheels and rear ends, basically.
There's also the thing that manufacturers want to sell you on the idea that bolts should not be re-used. In some cases, this is true.
K
Konrad
27
  • Aug 4, 2011
Yeah I figured it was one of those things that's better to do that way but not the end of the world if you didn't.
streethorse
1,042
Dallas Texas
Aug 4, 2011
  • Aug 4, 2011
I recently replaced a control arm, tie rod, and ball joint on my daughters
VW Beetle. All the nuts & bolts were 1 time use style, They came seperate
from the parts. Cheap insurance so to speak. I noticed they are tighter
when putting on. You cant just spin them on by hand, it takes a wrench
all the way down. Pretty much insures they wont back off somehow.
D
Progress Thread Today in the shed........
  • Don7Up
  • May 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Yesterday at 6:53 PM
Don7Up
D
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
Suspension 87 steering wheel slightly wobbles after new Rag joint install
  • R82148V
  • Jun 16, 2025
Fox 5.0 Mustang Tech Jun 24, 2025
R82148V
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
