One Wire Alt
  • Thread starter Thread starter rd
  • Start date Start date Jun 12, 2007
rd
3,316
63
109
Ocean Springs MS
Jun 12, 2007
  • Jun 12, 2007
Anyone running a one wire alt?
I was thinking of putting a 140 amp Powermaster 1 wire on my 82, and removing the external regulator. They say not to run under drives, so the pulley goes back to stock too.
Any tips, experience?
2stangBK
231
Central Florida
Jun 12, 2007
  • Jun 12, 2007
I just installed a Powermaster Bullet 140. Nice and and simple 1 wire setup and the chrome finish looks tight too! It works well on my mostly strip 91 GT. One thing you may check into is over-voltage on your old wiring. That may be your only issue to watch. I'm sure someone else has some experience with the one wire upgrades.
gambit90lx
  • Jun 14, 2007
jeg 100 amp 1 wire
so far knock on wood...i have a jegs 100 amp 1 wire alternator and i havent had any problems at all...i have march underdrive pulleys except to the alternator pulley i just went ahead and used the one it came with..
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 14, 2007
  • Jun 14, 2007
Save some $$$ and get a 3G from the junkyard for $20-$40. For a few extra dollars, most junkyards will give you a 1 year warranty.
I recommend a 4 gauge wire and a 125-150 amp fuse. I have an additional 4 gauge ground running from the power steering pump mount to the common chassis ground. You can put the engine side of the ground on almost any bolt on the engine except the timing cover or water pump bolts. They tend to corrode and make bad electrical connections.
Wiring parts & sources:
See WWW.partsexpress.com for the fuse & fuse holder.
Fuse @ $3.90 each (need one) http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=071-952
Fuseholder @ $5.80 each (need one) http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=263-630
4 gauge black wire @ $1.25 a foot (use string to lay out routing & determine length) http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=100-196
4 gauge red wire @ $1.25 a foot (use string to lay out routing & determine length) http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=100-194
4 gauge ring crimp terminals (package of 5) $3.25. http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=095-584
3/4 “ Black heat shrink tubing, 4ft length, $3.39
http://www.partsexpress.com/pe/pshow...number=082-058
3/4 “ Red heat shrink tubing, 4ft length, $3.39
http://www.partsexpress.com/pe/pshow...number=082-064
Pre-fab 4 gauge cables with lugs already on the ends are available in most auto parts stores. Look for the starter switch to starter cables.
Sicarius428
2,085
Jun 14, 2007
  • Jun 14, 2007
The 3G is far better than the powermaster. I have had both and the 3G charges much better at idle, which if you have an e-fan is when you need the extra amps most. The 3G looks a lot cleaner without the cooling fins coming out and the 6 gauge wire that my powermaster came with was useless. You will need a 4 gauge wire to your solenoid or battery terminal with a 100 to 150 amp fuse... depending on your draw. I chose a 100 because I rather it burn out sooner. I dont have a serious stereo yet...
Kevin
rd
3,316
63
109
Ocean Springs MS
Jun 14, 2007
  • Jun 14, 2007
Thanks for the feedback.
I got a Powermaster 140, mostly because I did not want to do any more wiring and adapting than I have to.
I am hoping that this: Fits the 1980 serpentine bracket.
Does not require any wire changes.
Does not require rewiring the ext regulator
Does not need an extra set of wires to the cut off switch.
The only prob so far is that I have to run a new switched wire from somewhere to the choke heater, as I had been using the stock Ford unregulated output wire.
I have thought about the 3g upgrade, etc, but my experience with salvage yard parts at this point is that it takes too long to go there, find one, remove it, etc. Especially if it needs to work, not just look good.
That said, I spent 4 hours last Sat in a salvage yard removing tailight bezels from a 66 Malibu to install on mine.
So the Mustang has to make do with new stuff. I can make up wires if necessary.
The 3g does make a lot of sense, and I may go to that on the Capri, when I go with electric fans, or on the 82 if this doesn't pan out.
Electrical 91 hatch wiring help needed
  • FastDriver
  • Apr 7, 2026
Fox 5.0 Mustang Tech Apr 8, 2026
FastDriver
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 22, 2026
  • dan50
  • Jul 18, 2026
dan50
