John, could you do a little write-up on this if you have the time please. It looks you welded in reinforcement plates on the bottom, correct? Does moving the perch cause the spring to interfere with the outer spring housing, especially if it has been modified for tire clearance as in a previous write-up of yours? Does it lower the front end at all as the base of the triangle is lengthened while being countered by an improved spring ratio? Any alignment issues?
I'm doing some front end work and want to take advantage of the down time as much as possible. I run a machine shop, so doing the work myself (I'm doing roller perches as well) isn't a problem.
If you have time please I'd really apreciate it and it would be a good tech thread for the other members, I'm sure.
Thanks, Krash.
Thanks, Krash.
Opentracker said:.....you can improve the motion ratio by moving the spring perch forward on the upper arm.
The spring perch location has been moved 1 1/4" on these arms. With this mod the motion ratio goes up from ~0.6 to ~0.73, making the wheel rate 1.5 times stiffer. Not bad for an almost free mod.
. You are in Austin I see, been down there a few times to talk to Cisco guys. Enjoyed my trips.
