OPINION WELCOME!
1980coupe
CHICAGO
JUST CONVERTED MY 80 COUPE TO A 5.0 5 SPEED! USE TO BE A STRAIGHT SIX AUTO! I USED A 84 GT AS THE DONOR BUT THE 80 DOES NOT HAVE THE QUAD SHOCK MOUNTS AND THE HOLES IN THE CONTROL ARMS FOR THE SWAY BAR! SHOULD I YANK THE GT CONTROL ARMS OUT AND QUAD SHOCK MOUNTS AND FAB THEM TO THE 80 COUPE? OR CAN CAN I DO WITH OUT THEM AS FAR AS DRAG RACING IS CONCERNED! OH AND YES I USED THE COMPLETE SUBFRAME AND SUSPENTION FROM THE GT AND WHAT A DIFFERENCE I TELL YOU!
first.. turn off your caps lock.
second just swap the entire rear-end. if you do not have the mounts on the body just weld on a big bolt. ive seen it done. and for drag racing no you dont need the sway bar but for everyday driving i recomened it.
I fell into the quad shock do it or don't. I searched on here and got some advice and finally took them off and my car was crap w/o them. so I put them back on and now I'm fine. seems like a crap shoot on what mustang will do okay with or without them. I'm not saying punisher is wrong but you might have to do a test with them and w/o. some on here say yes you have to have them and some say no, I did the experiment and my car failed. oh I had just replaced the upper control arms and bushings, and new rear shocks before doing this test.
i just took my 80 out today for a test run and it is wheel hop crazy and i cant launch worth a ****! i am going to take the quad shock mounts off my 84 gt donor, however im going to have to weld the quad shock mounts onto the 80 frame! is the 84 gt hatch the same frame demension and length as the 80 coupe or do i have to pretty much eyeball it??? and if i have to eyeball it how much tention is needed on the shock it self from the fram to the rear end???
Instead of mounting quad shocks and if you have the funds to do it, purchase a set of quality (read MM) lower control arms and replace the uppers with 94+ OEM pieces with some new rubber bushings. If you don't have easy access to a set of 94+ uppers, I believe that MM has those as well.
If you want to get REALLY fancy, toss a panhard bar in there. You could then run any bushing you want in the uppers.
My 82 is also a straight 6 to 5.0 conversion.
I still have a 7.5 in non quadshock axle in there, and have used an 8.8 in it for a couple runs.
I used the 1982 control arms and boxed them. Stock rubber bushings and all.
Still wheelhopped, so I put on my old set (1985) of Lakewood traction bars, and it cured it. It will pull high 1.80 sixty foots on Drag Radials this way.
I would not bother with the quad shocks.
Yeah... it's pretty tough to NOT have wheel hop with rubber bushings in the lowers with no quads. There's just too much play in the rubber bushings and its compunded by the flex in the OEM control arms.
Yup i agree with daggar. with flimsy stock control arms and rubber bushings its going to be next to impossible to eliminate wheel hop without the quads in there.
If i were you i would toss some maximum motorsports lower control arms in there for a couple hundred bucks. Weld a bolt onto the chassis for the quadshocks...and box the stock uppers and put new bushings in. You would see a world of difference.
thanks for all the opinions out there but i think im going take the quad shock mounts off my 84 gt and use the quad set up on my 80 for right now! im planning on tubbing the car next year putting a narrowed 9" with ladder bars! i want to build a 351w for it but my buddy keeps saying lets go with a 460 but i dont know i think 460 is alot of motor to work with not to mention the tight space in the engine bay!!! what do you guys think???
