Opinions on fuel pressure regulators
rio95
829
Grand Rapids, MI
I have pretty much made up my mind by going with a Kirban with a guage. This is one of the best ones out there isn't it. Also, what use would a FPR be without a guage. I thought they all had guages, but now I know they don't.
Just to check, this will work with a street heat fox set-up correct? The only thing that really matters is the fuel rails right?
Is this the best deal?
http://cgi.ebay.com/ebaymotors/ws/e...tem=7975484861&category=33553&sspagename=WDVW
I'd say that a good deal...gage and the fittings with it....
I run the 93 Cobra with a Kirban and plenty of clearance...I wouldn't think it would be and issue...Never really hear of a complaint with Kirban..
Plenty of real estate....if your running stock fuel rails your ok...
FWIW....check this link...make sure you get the correct one...2 different P/Ns between ours and the Fox...pics look the same but dif P/Ns...??
http://www.proficientperformance.com/kirban_fuel-system.php
I am opposed to running a full time gauge under the hood. I have a hand held gauge I hook when I am testing the FP, when I'm done I remove it. I have heard of too many bad situations where the rail mounted gauge either leaked or broke and had the potential to start an engine fire.
Edit: I have run a Kirban on my car since '98 without any problems. The 94-95 and fox differ in the number of "fittings" for lack of a better term are under the gauge that go into the rail. They are NOT interchangable.
Off topic sorry...
Rio, you're running a Fox Cobra upper/lower intake on a sn95? It doesn't look like you're running an intake elbow or anything. What mods did you have to do to make this work?
I am also not a fan of having a gauge full time (though SO many folks do with no issues). I have enough things break w/o having one more thing there to break. :)
the Kirbans are very nice and rebuildable, IIRC. i do like Paul and toss my diagnostic FP gauge on when i need to check pressure.
good luck.
MrClean302 said:
Off topic sorry...
Check the sticky thread at the top of this forum on the fox TB swap. Its a pretty common thing to do now a days.
