Is there an option, besides using the TC VAM or SVO setup?
For example: 5.0s with superchargers use a FMU for fuel, a BTM for timing retard and a Mass air calibrated to injector size.
So hence the questions
Will using a stock 89 N/A computer with the above-mentioned items (FMU, BTM and Mass air) suffice a turbo installation?
C&L mass air meters offer a large selection of sample tubes for adjusting to injector size, I’m wondering if a stock 19LBS injector tube for a stock 5.0 would work on a 2.3…. It did on my 92 Super Coupe…C&L or most meters are not based on injector size (injector specific) but are specific to the computers set stock parameters …..93 Cobra runs a 24lbs injector, Super Coupe 30lbs and 90LX 19lbs……all use the same Mass air calibration= 73mm mass air set up for a 90lx 19lbs injector will work in all three vehicles mentioned, so does this stuff carry over to a 2.3????
How is timing controlled in a TC? Is there any retard per lbs of boost?
When using a BTM you could run a ton more lead/ advance (low end torque…less lag) and then pull it out up top. Is this applicable to a 2.3 turbo set up?
Sorry for the questions, just been a 5.0 guy for a long time (just don’t have the cash for blown 5.0s anymore
) but still have some goodies lying around.
