Ordering a new Lokar Throttle cable, kick down, and throttle bracket. But 1st some ?s
jerry S
1,365
52.22N 5.12E
I have a 1969 Mach 1 with a 351W.
1. Do I need a 24 or 36 inch throttle cable?
2. Do I need any other parts to make the kickdown cable mount to my Holley 4150 series carb?
3. is the Lokar throttle bracket the best one out there or should I consider something else? I want a throttle bracket that can accomodate the kickdown cable and I don't see any that do this other than the Lokar.
i got your pm
my set-up is a 24" cable, but it still needed like 6" cut from it to make it fit. the kick-down on mine is for an aod, actually a TV cable. it will just connect to the ball socket on your holley. the lokar bracket is nice, it;s stainless, which is nice too.
if you've seen mine its a little different then some, its actually not a throttle cable, it's their blower drive, exactualy the same except for the heim joint on the end instead of the ball socket. this was because i wanted something slightly different and the throttle plate was different on my demon then a holley.
sorry for the bad spelling/grammer, holding a squirgmy baby right now......
streetgrande69 said:
also on the pedal end you'll need to slightly modify the end, it only took 5 minutes. i just straightened the end ans slightly filed it to get the clevis to go on the pedal. i can get a pic if you need.
A pic would be helpful. Thanks in advance.
regards,
jS
