ordering some stuff tonight
autumn_again
356
Hamilton, NJ
okay, basically first time ordering stuff for my car. i'm ordering the ford racing 3.73 gear kit.
what other things should i order that are cheap, that i would notice a difference with.
little things like underdrive pullies and etc.
i am not going with exhaust yet, until i can afford to do new headers and mid pipe and cat back at the same time.
i'm probably going to order from late model restoration, unless i am recommended a cheaper place.
thanks.
You should replace the axle bearings and seals while you are down there.
Pulleys are definitely a cheap, and noticeable mod.
I would do the catback and midpipe if you can afford it. New headers won't do much for your stock car. Unless you plan on going with longtubes, then it's a smart idea to wait till you get both. But I would definitely do a catback as long as the funds are there.
:flag:
Dump the cats, get an H or X pipe, even if you have stock mufflers it'll make a big dif...
A homemade CAI and pull the lower intake and have Tmoss port it... Do those and the gears at the same time and youll be amazed at the difference...
:flag:
i've got flows for a catback now, but i'm thinking going
long tubes - off road x - slp lm2.
i dont want to spend too much, because in less then a month i'm buying another 5.0 that im going to be building up.
