ordering vortech in morning did i get a deal ?
clutchpopper said:
Thanks for all the info. I have decided to get the kit they have for $3299.99 it comes with 42lb injectors, Walbro GSS317 (255lph) pump and a chip either from diablo or superchips that is burnt for my application and mods ,is this cool?
from what i've researched, you can have a SOLID, COMPLETE ready to bolt-in kit from T&J for a few hundred bucks more. that eliminates the chips and reflashes the car's computer with an adaptive tune. The guys at T&J have done quite a few S/C kits using the adaptive tune, no internal beefing, and hit the magic 400 rwhp mark...and most importantly, have NOT tossed a motor! Pretty good track record!
scheister said:
hehe...is it just a coincidence that over 90% of the guys on here vote for the Cobra Killer Kit?:D
I think the best thing about the Cobra Killer kit is not the blower or tune...it's the fact that you got it from TIM. That will make a huge difference in the long run if you have any problems or concerns. If you look on the boards for people who got a vortech kit and had problems you'll probably see at one point or another they are asking Tim for advice.
Buy the Mongoose kit from Tim trust me. You may spend a few $$ more at first but in the long run you will save yourself a ton of headaches. Trust me as I had a 02 GT with the Steeda Vortech Setup (same as Tims kit almost) and I never had a problem yet my friend who also has a 02 GT put the kind of supercharger kit that you are thinking about and he has spent way more $$ than me on tunes alone trying to get the damn thing to stop pinging and to idle smooth.
Jeff B.
jstreet0204 said:
I called them to get more info. The only things you need for this kit are a fuel pump, injectors, powerpipe, and a tune.
I guess you could still make a mongoose kit of out that...might want to give tim a call and see what your options are if your curious.
I did the same thing you did by buying the tuner kit and picking the other parts need .if you still need a maf you can get a lightning maf for $190 i also suggest going to your local dyno and having the car dyno tuned you can usually purchase the chip from them for 300 and have it tuned for 100-200 sound expensive but it gets you more power and let you know what your air/fuel ratio is through out your rpms. This could be very important if you don't have a forged bottom end. good luck
clutchpopper said:
If diablo or superchip Tunes the my chip I wouldn't have to worry about vortechs tunning would I ?
Thanks again
Why dont you try researching this before getting into it. The car MUST be dyno tuned. A crappy supplied chip for your application will proabbly not even let the car startup nevermind having a perfect detonation free 12.5/1 a/f ratio with optimal timing.
