OT: Need help
  • Thread starter Thread starter KillerKittyCat
  • Start date Start date Jul 24, 2004
KillerKittyCat
150
Hammer Down - Behind The Wheel
Jul 24, 2004
  • Jul 24, 2004
The topic is fuel pressure.
On the Kitty and the Pony I can put my finger over the pressure hose off the fuel pump and know if I have the needed fuel pressure.
Real quick story. I have been playing with the SuperCoupe and the wife turned it sideways when she slipped on the accelerator. So the Doctor had a really nice 740 Volvo which I bought for her. Something happened overnight. It idles fine but surges between 800/1200 and will not go beyond 1200. Is this a fuel pressure problem or something else?? (specs say 38 psi but I can not find a repair manual for that model - in town - if I tried any harder)
Am I looking in the right direction or am I sleeping on the sofa until Volvo opens on Monday? Could it be the computer??
(Two pumps - can you believe that)
2BAV8 - Please do not read this.
Thanks
mustang70
2,445
San Diego
Jul 24, 2004
  • Jul 24, 2004
38 psi is about standard for a fuel injected motor. It sounds like something else is hindering it. Have you tried revving the motor at the throttle body?
KillerKittyCat
150
Jul 24, 2004
  • Jul 24, 2004
YES!!
mustang70
2,445
San Diego
Jul 24, 2004
  • Jul 24, 2004
What about ignition? The surging might be from a miss somewhere.
2nd Mustang
2,488
Southern California
Jul 25, 2004
  • Jul 25, 2004
Clogged air filter? Clogged fuel filter? Worn out oxygen sensor? Any codes available?
KillerKittyCat
150
Jul 25, 2004
  • Jul 25, 2004
Replaced the fuel pump and filter. Changed the mass air flow sensor and both engine relays. NO CHANGE!!
My guess is the O2 sensor or the throttle body sensor. Something is telling the ECU to shut down the injectors.
As far as codes, I can not find a book which tells me anything
mustang70
2,445
San Diego
Jul 25, 2004
  • Jul 25, 2004
I would go with the throttle position sensor. If it was the O2 sensor then the engine would rev up, but it would be choppy or shoot black smoke out of the tailpipes.
  • dan50
  • Jul 18, 2026
dan50
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
A
need help and advise
  • amps1956
  • Oct 14, 2025
  • Other Auto Tech
Other Auto Tech Oct 21, 2025
Mcmahst
'04 V6 running rich excessively on both banks
  • 04DSGVert
  • Oct 26, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Oct 27, 2025
04DSGVert
A
Resolved 1989 Mustang bogs down after 3-5 minutes of driving.
  • Alabama
  • Feb 11, 2025
2K
Fox 5.0 Mustang Tech May 26, 2025
limp
