I have a 351w efi in a 92 fox that runs like complete crap accept w/o throttle or if I unplug the o2 sensors. Symptoms are it runs extremely rich,has a miss below 2500 and hesitates when you hit the pedal. I have new o2's and a new o2 harness, I've changed the tps,m/a,act,ect,changed injectors, searched for vacuum leaks, changed fuel pressure up and down, changed timing up and down, checked TDC for dizzy, done comp test( all cylinders 155 give or take 3 pounds),I ran computer test ,codes were engine off(31 67 81 29 41 91 ) engine on (94 44 31 61 81). I did have the egr off so I put it back on the car it is hooked up with vacuum but its not on the engine itself do to I have a spyder intake. nothing has worked except to put it into open loop, but the car gets 9mpg and blows smoke like a freighttrain when you get on it. I also have cleaned all connectors and checked all the grounds. One question I have is it possible to fry part of the ECU but not the whole thing? I have tried everything I can think of, please any input would be appreciated
