  • SN95 4.6L Mustang Tech
Output speed sensor circuit malfunction
  • Thread starter Thread starter waterboy1270
  • Start date Start date Jul 11, 2006
W
waterboy1270
  • Jul 11, 2006
My 01 gt auto just had a torque converter installed, and ever since ive had trouble with this check engine code (P0720- Output speed sensor circuit malfunction). The check engine light comes when i stall the car above 2000 rpms and launch or do a really nasty burnout. And when the light comes on the car bogs down to 3000 rpms, the overdrive light flashes on and off, and the odometer reads blank miles. This has only happenned to me at the drag stip. Does anybody know anything about this code? Or what i could do so that the light doesnt come on anymore and the car doesnt bog down? Thanks alot.
-70mm throttle body
-3500 stall converter
-SFC, LCA's
-Shorty headers, Full flowmaster exhaust system (x pipe)
-Hypertech power programmer (shifts programmed to 5800)
-4-10 gears
-MT street Et's
-KN air filter, oil filter
d98gt
4,505
59
204
SE Texas
Jul 11, 2006
  • Jul 11, 2006
Have you checked to make sure the plug is connected in there firmly? My plastic "locking" piece was cracked so it wasn't staying on all the way which was resulting in the codes being thrown. At first I was worried since I just had bought a new VSS sensor and still was left with the same problem.
W
waterboy1270
  • Jul 12, 2006
To tell you the truth, i cant find out where the sensor is hooked up, i thought it was on the output shaft of the trans but i couldnt find it anywhere. If you could tell me where it was, i could check it out, thanks a bunch.
d98gt
4,505
59
204
SE Texas
Jul 12, 2006
  • Jul 12, 2006
I'm not certain that this is your problem by any means, but it'll cost you nothing to check
View attachment 456442Plugged in
View attachment 456446unhooked
It's located on the driver side of the car towards the end of the tranny.
W
waterboy1270
  • Jul 12, 2006
Hey man thanks for the nice pics! Ill check it tomorrow and write back. Thanks!
T
2003 GT cluster issue
  • Timothys gourmet
  • Aug 26, 2025
SN95 4.6L Mustang Tech Aug 28, 2025
Mustang5L5
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
Dangerous High RPM at stop/ RPM Jump when switching to Neutral then dies.
  • 02torchvert
  • Dec 17, 2023
SN95 4.6L Mustang Tech Jan 3, 2024
Yel2002GTAuto
Y
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
