Overdrive Complete Transmission For 1970 Ford
you can swap an AOD into the car with ease. you need the larger 164 tooth flexplate with a 28oz balance factor. you also need a lokar TV cable to make it work properly. you should also get an AOD output yoke. you will need the larger AOD block plate, and modified cross member, and you should get the floor shift model AOD. after that it is just putting everything together properly.
