  • SN95 4.6L Mustang Tech
overdrive ?
  • Thread starter Thread starter 4.6boy
  • Start date Start date Jan 29, 2008
4.6boy
187
  • Jan 29, 2008
is it ture that if u drive in overdrive all the time ur trainy will get worn out faster?
also going down a 1/4 mile is it better to not be in overdrive
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jan 29, 2008
  • Jan 29, 2008
Overdrive gear is actually utilizes band clamping around a drum to perform it's gear selection and not a set of clutches under direct pressure like the other forward gears. So yes, it's more subject to wear than the others. I would recommend turning the O/D off for quarter mile blasts or any towing applications where the O/D might become subjected to stressful situations. That being said, I've seen cars go 200-300k utilizing their standard Overdrive Gear placement selection for daily driving, so I wouldn’t put a whole lot of thought into it in that case. One of the best things you can do for your transmission’s longevity would be to add a plate style external transmission cooler to the mix. Keeping the ATF cool should always be your primary concern.
4.6boy
187
  • Jan 29, 2008
thanks any kits u would recamend
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jan 29, 2008
  • Jan 29, 2008
B&M has a nice selection of transmission coolers. What ever you decide, go with the stacked plate style over the tube and fin style. They're more efficient at removing heat.
C
Stock 1993 charging issue at idle
  • Charlie1
  • Sep 21, 2025
Fox 5.0 Mustang Tech Sep 24, 2025
Mustang5L5
J
Transmission issues 4r70w
  • Jess!08249
  • Nov 12, 2024
1996 - 2004 SN95 Mustang -General/Talk- Nov 14, 2024
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
R
Wow, Tire Issue on 2019
  • Rcdgl
  • Dec 30, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Oct 11, 2026
Rcdgl
R
