overflow bottle
The bottle in this one, i dont think is original.
The last guy put this giant in there (its about 1 gallon and basicly square)
He mounted it where the battery tray is, since my battery is in the rear.
I am interested on what you were planning to make.
Stainless? 3x8?x15? PVC pipe? Capped or just plugged with drain and fill fittings? Recirculated or just drained?
I was into the HHO scene for a while.
They generate higher temps with thier liquid, and use PVC and Poly/Lexan tubes for different things.
I was thinking of puting together a new over flow out of 4in PVC, but didnt get that far yet.
john i will take a pic of mine today when i get home from work, its and aftermarket one it hides in the fender real nice, its black so i hope it shows up in pic :shrug: we shall see:nice:
You can see it in the front:
I just bought a generic summit brand one, but the vent hole was super small, and cause of this, the tank was getting pressurized and overflowing. I opened the hole up to around 3/8" or 1/2" and it solved the problem. So if your not making a recirq tank make sure the vent is large enough
