Overflow Question.
billison
I like tinted tail
2,607
1,094
184
stl
using a universal overflow bottle. I have the coolant line ran to the bottom of the tank. The tank has the cheap flip up cap for a lid. Do I need to add a hole for venting or is it fine?
overflow? You need one because when the engine gets hot the coolant expands and will begin to overflow and if you dont have a recovery tank it will do two things- one piss out coolant all over the ground and then when the motor cools down the coolant actually is sucked back into the radiator. If you dont have the overflow you run the risk of low coolant. in the radiator and overheating
