overflow resovoir ?
  • Thread starter Thread starter sgarlic
  • Start date Start date Nov 14, 2004
sgarlic
3,085
Nov 14, 2004
  • Nov 14, 2004
Hi guys, quick question about my 88 GT. On my coolant overflow tank, I have a hose on the bottom that connects to the radiator by the cap.. and then right below the cap of the overflow tank there's a plastic piece that curves around and faces downward.. in reading my Chilton manual I can't find anything describing what this is supposed to be connected to.. does that top curvy plastic thingy do anything?
I ask because it says the radiator will draw coolant from that tank, and put excess coolant back in.. does that bottom hose serve both purposes?
HISSIN50
34
129
Nov 14, 2004
  • Nov 14, 2004
yep, the bottom hose is for fluid to ingress and egress from the rad. the top molder opening should be an overflow for the overflow. if it was not there, coolant would burst out the top of the reservoir if overfilled. it should just dump onto the ground.
P
Mishimoto Radiator leak 1987 Foxbody 5.0
  • PHoffman
  • Jan 16, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 18, 2025
Trogdor
M
  • mnky99
  • Sep 5, 2025
mnky99
M
Engine Kinked overflow tank hose.
  • 91GTstroked
  • Aug 21, 2021
2K
Fox 5.0 Mustang Tech Aug 21, 2021
91GTstroked
Engine How common are blown head gaskets on a stock 5.0?
  • 91GTstroked
  • Dec 7, 2021
8K
Fox 5.0 Mustang Tech May 6, 2022
shindokwan
A
1991 5.0 with HCI - started car, running for a few minutes, started pushing coolant into the overflow tank and then puking out from there. I'm lost
  • AmericanMuscle4.6GT
  • Oct 16, 2022
4K
Fox 5.0 Mustang Tech Nov 30, 2022
CAMTWO1070
