I read thru every post I could find, but I need a bit more info/advice.
I have a 289 3 speed standard with edelbrock heads and intake, unknown cam.
It has been bored 60 over.
I've replaced head gaskets, put in 3 core radiator, replaced sending unit, and replaced thermostat. Oh checked hoses, and lower hose has spring inside it to avoid collapsing.
Before I put on the air conditioner it ran in the normal temp zone, so I suspect the a/c condenser is the problem, but not posative. I live in Texas, so I REALLY want the ac.
I believe it is not the gauge, because when it says its hot, the engine is making ping noises, and if I turn it off it is VERY difficult to start. I have not measured the water temp with a mechanical gauge.
What happens is that when I drive highway or city it heats up to the line just before H. What is weird is it doesn't seem to matter if I have the a/c on or not.
The things still to try that I've read:
0) In process of putting cowl (spelling) on, I have to redrill it because 3-core doesnt match up.
1) Bleed the water system, but I could not find any description on how to do this.
2) replace water pump (thinking of a high volume one, any suggestions on brand?)
3) pull all the freeze plugs and clean out inside engine.
4) (next to last desperate act) upgrade alternator to higher output (any brand suggestions here?) so I can put on an electric fan (looked like mark iv from junkyard was best bet?).
5) (last desperate act) yank the engine and put in a new crate engine.
So any hints or advice would be welcome. I am really worried that the condensor is just blocking too much air, but I don't know how to fix that. I thought about moving it to face down toward the ground and put an electric fan on it, but that sounds like a serious pain.
Only draw back is living on a dusty road,
Your shooting yourself in the Foot.
