overheating...again
  • Thread starter Thread starter p.exeter_bleu
  • Start date Start date Dec 14, 2004
P
p.exeter_bleu
293
El Paso,TX
Dec 14, 2004
  • Dec 14, 2004
in the past ive had some overheating problems, i replaced the tstat with a 180* one, got myself a 3 core radiator, and thought the problem would be solved. i dont have a blown head gasket. it runs perfectly while im driving in my higher gears like on a freeway but when i hit the low gears in the streets the temp creeps up. what could this be? please help me out. i let the car idle on saturday for a good 40+ mins and it never overheated, i took it for a spin around the block and it seemed ok. today i drove it across town what should be 30 min drive, and this is when my problems surfaced with the creeping temp. as soon as the temp was rising i pulled over to take a look and i hadnt fully tightened the upper rad. hose was this my problem?
HISSIN50
34
129
Dec 14, 2004
  • Dec 14, 2004
what is the cooling fan situation? rad cap new?
it sounds more like an ancillary component (fan, etc, as it is always good? on the highway).
ya sure all the air is out of it?
factory or aftermarket gauge being used?
good luck.
PNY PWR
522
Wichita, KS
Dec 14, 2004
  • Dec 14, 2004
I'm looking for our other thread that covers alot of this, I was just posting on it last night.
Here it is, read this over and see if helps you out any.
http://forums.stangnet.com/showthread.php?t=524712
P
p.exeter_bleu
293
El Paso,TX
Dec 14, 2004
  • Dec 14, 2004
hissin, factory gauge, fan and fan clutch im not too sure on, seem ok. im assuming that when the upper hose wasnt tightened down, maybe some air seeped in?
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Dec 14, 2004
  • Dec 14, 2004
If it's full (burped - no air in the system) then low speed overheating is almost always related to not enough air moving across the radiator. Has your fan clutch failed?
Funanin
356
Horsham, Pennsylvania
Dec 14, 2004
  • Dec 14, 2004
make sure ur thermo isnt in backwards
check ur water pump and make sure it doesnt leak and that it still spins. (look inside ur radiator while it is running and check to see that the fluid is moving around good.) Also that there are no bubbles in the coolant system from a crack in a head or gasket.
check ur mix (water/coolant)
try adding water wetter. Its like 10 bucks and drops temp up to 20* guarrenteed and it worked on mine.
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
G
2016 GT, Cold Air/Tune Trouble (overheating) . Advice/Help Please!
  • GLStang
  • Sep 6, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Sep 6, 2025
O
2001 mustang gt overheating
  • orinsmiley11
  • Jul 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 17, 2025
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
D
03 mustang Mach 1, 4.6L None Supercharge
  • DangStitches
  • May 18, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 23, 2025
