OverHeating Don't know whats up
  • Thread starter Thread starter Djstorm100
  • Start date Start date Aug 5, 2007
D
Djstorm100
109
  • Aug 5, 2007
I have a fully built 302, compression lower to 8.5:1 blah blah The problem is when i'm on the highway it gets to 200ish water temp. When i'm in stop and go traffic the thing wants to ping up to 230ish. I turned my heat on full blast and go it to lower down. Well I took it out later that night and I got in it like a mother. Needless to say it was about 70ish, and it would go up to 200 but then drop back down to 185. I think it maybe the fan. I have a flex a lite Thin series on there with no shroud. I have a 2 core fluidyine (spelling) radiator. The fan I have on there now from what I got from flex a lite flow 2,000 CFM. I was thinking of getting a SN95 fan OR get a Mark VIII fan. Yes I have replaced the thermostat with 180. I'm going to get the radiator flow check tomorrow. Its 2 inch thick 24 inches long and 17 inches high. Would the 3 core from napa be better cooling wise?
Sorry I'm in a hurry so if anything is unclear I'll fix it when I get home.
D
Djstorm100
109
  • Aug 5, 2007
the guage I'm going by is autometer c2 guage
HISSIN50
34
129
Aug 5, 2007
  • Aug 5, 2007
Welcome to the boards! Is this a forced induction vehicle?
I'd agree that at a minimum your fan situation needs to be addressed. Also, do you have any sort of air deflector under the car?
Good luck.
D
Djstorm100
109
  • Aug 5, 2007
Good luck.
yes it is forced induction (vortech v1- trim)
Honestly I dont think so, In all honestly dont kow what one would look like
D
Djstorm100
109
  • Aug 5, 2007
any other ideas?
what year mark 8 fan should I get.. I want the fan that flows the most CFM
also what tools do i need to bring to the junkyard to take it out?
HISSIN50
34
129
Aug 5, 2007
  • Aug 5, 2007
If you look under the car (from the front), find the area below the radiator. There should be a piece of plastic going across there. It's like a 15 dollar item if you need one.
I haven't pulled a Mark VIII fan off a J/Y car so I dont know what all you need. One would certainly think that a cheap socket kit (with metric and SAE sockets) and a couple of short screwdrivers would work (I have a J/Y kit that comprises that stuff, plus a multitool for cutting wires, the need for pliers, etc).
Good luck.
D
Djstorm100
109
  • Aug 5, 2007
any certain year I should look for MK8 wise? wasnt there a year that they made the fanest the strongest? (pulled the most cfm) of was all the years the same 93-98?
D
Djstorm100
109
  • Aug 5, 2007
also the air deflector is on the sides of the radatior correct? If so I only have one on the passenger side
G
Gunnerm1
  • Aug 6, 2007
think you said that it is an electric fan, if so, check the polarity. If it is reversed it will push the air back into the radiator as opposed to pulling the air out. A good friend recently had that happen to him, he tried everything and I suggested my simple fix it actually worked. Anyway good luck, and keep us posted
Engine 1986 GT Overheating issues
  • 86 5O GT
  • Jan 25, 2026
Fox 5.0 Mustang Tech Jan 29, 2026
86 5O GT
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
Saying Hi
  • BriansNSane
  • Dec 20, 2025
  • The Welcome Wagon
The Welcome Wagon Dec 21, 2025
BriansNSane
