  • 1994 - 1995 Specific Tech
Overheating Help
  • Thread starter Thread starter HighTech1011
  • Start date Start date Aug 30, 2008
H
HighTech1011
Chesterfield, MI
Aug 30, 2008
  • Aug 30, 2008
It was suggested to post this here, so here it gose.
I've been having an overheating problem with my GF Mustang for about 3 weeks now. About a month or so ago she blew the upper coolent hose and I replaced that. Now if the car does anything under 45 mph the temp starts rising, and doing anything over 45 the guage just holds steady. Upon closer inspection, I noticed the fan never turning on. Following instructioin in the Hayes manual, traced it back to a bad relay in the CCRM, what the local dealership verified. Replaced the CCRM and it worked fine.
A couple weeks later the dealership my GF bought the car from rewired their GPS into the car, messing with the wiring under the stearing wheel, and a few other places. Now the car is back to its overheating issue, and the fan doesnt turn on for anything, including when the A/C is on. The Fan tests out fine (connected it to the battery and it turns), followed the Hayes manual and everything tests out fine... only tings off is the resistance to ground of the fan (reads 5.8 ohms instand of 5) and both collent temp senders read a little high (withing 10 to 15 ohms) when cool, but read right when at running temp.
I'm at a loss on where to go from here. The dealership claims what they did would have no effect on the car. I thiought someone might be able to shed some light on the topic for me. Her Mustang is a 95 base model, no add-on, no frills. 3.8 L V6, manual trans.
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Aug 30, 2008
  • Aug 30, 2008
Hook up a code reader to the car and check out the coolant temps. It's possible the ECT sensor is out and the computer is getting the wrong temperature reading. Happened to my V6 and it was an easy fix. The Mustang V6 is an OBDII car, so the plug under the driver's side dash works.
H
HighTech1011
Chesterfield, MI
Aug 30, 2008
  • Aug 30, 2008
Any specific code reader you suggest?
HISSIN50
34
129
Aug 30, 2008
  • Aug 30, 2008
Also consider doing manual fan switches in case this occurs again.
W
High Cylinder Head Temp - Not Overheating?
  • wtfwork12
  • Jun 26, 2025
2K
2005 - 2014 S-197 Mustang -General/Talk- Jul 1, 2025
wtfwork12
W
G
2016 GT, Cold Air/Tune Trouble (overheating) . Advice/Help Please!
  • GLStang
  • Sep 6, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Sep 6, 2025
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
Help with window and possible engine
  • StefRena22
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2025
Willybill32
