Make sure your water pump is not going bad -- look for oil coming out of the weep hole, run the engine with the radiator cap off and look inside for coolant flow when the thermostat opens.
You can flush the radiator, but I'd recommend replacing it. New replacements can be found for less than $200. Old radiators start to leak, and people often put stop-leak products into the system. These are meant to be temporary fixes, and if left in there can clog up the cooling system. Getting the system flushed may get rid of the clog, but then you'd probably be left with the original leak.
Have the radiator cap pressure checked, or just replace it.
Check the fan clutch. With the engine off and cold, spin the fan. It should spin with little resistance. Warm the engine up, shut it off, and check the fan again. It should be harder to spin by hand when the engine is hot. If it's not, replace it. Since you're overheating at highway speeds I wouldn't suspect this to be the problem, but it's worth checking.
Check your fan for cracks at the base of the blades. This is not a part of your overheating problem, but it is a common problem on the 5.0L. Having your fan disintegrate would be bad.
