Ok have a 92 LX. I bought the car from a friend. I have replaced both HG, replaced lifters, pushrods, thermostat. He told me the car would overheat so I replaced everything I thought would need to be replaced to correct the situation. Here are some symptoms.
Car starts up fine. Idles fine. I can drive the car for about 3 miles, when all of a sudden the temperature will climb straight up FAST.
If I keep the car idle it doesnt ever climb that fast. I beleive the WP is fine because as I stated it runs fine idling but under load it climbs.
Now I am also leaking water around the EGR spacer, not sure why but any help would be appreciated.
I have a question about the thermostat. Does the thermostat go in the Intake or does the "spring" go in the thermostat housing.
I have drained the and flushed the coolant several times however when it overheats the water comes out real rusty color. Any help?
I did a search and I see alot of "air Bubbles" listed as a possible cause. Please tell me how I can correct the situation.
Thanks again.
Stefan
Thanks again.
Stefan
Your spring on your thermostat goes IN the intake; the reason is there is wax there that melts when the car gets up to temp, the spring allows the thermostat to open and coolant flows to the radiator which is air cooled and sent back through your system. If your spring is any other way than inside the intake, change it.
Then I added my coolant/distilled water combo. That's right, distilled water. My GT has no "tap" water in it. The reason it has minerals in it and some say it corrodes the cooling system. My Jeep and LX 5.0 run with tap water and anti-freeze, however. You do want to run at least 50% anti-freeze though. Not only does it prevent freezing, it also raises the boiling point of the water.
I searched and re-read a post or two of yours about cooling issues and you did indeed type the radiator neck. It makes sense and now I got it
