Overheating problem
  • Thread starter Thread starter gcwh02
  • Start date Start date Jul 16, 2007
gcwh02
515
pottstown, PA
Jul 16, 2007
  • Jul 16, 2007
I took my car out for a spin today and the temps rose to around 210. I have a taurus fan w/ dcc unit, afco aluminum rad, and edelbrock water pump. Any suggestions to why it rose that high?
88GT17MA
289
  • Jul 16, 2007
With that setup it should not be getting that high. I would check to see if you have air in the cooling system. Your headgasket isn't on backwards right?
HISSIN50
34
129
Jul 16, 2007
  • Jul 16, 2007
More info please.
How hot is it there (ambient temps)?
How long did the temps go up and did they stay up or come back down?
If they didnt come back down for awhile, did they come back down once you got up to a sustained 45 mph or so?
If you don't have a performance T-stat (I like Mr Gasket, but Robert Shaw and others work fine), get one. They dont suffer from hysteresis like parts store units do and they open fully sooner than parts store units. I have the feeling you have one already (since your other components look good), but it was worth mentioning.
Good luck.
conartist
77
Windsor, Ontario, Canada
Jul 16, 2007
  • Jul 16, 2007
Did you remove the front lower air deflector? Most foxes need this for proper cooling.
gcwh02
515
pottstown, PA
Jul 16, 2007
  • Jul 16, 2007
yup, and im a retard and threw it out
gcwh02
515
pottstown, PA
Jul 16, 2007
  • Jul 16, 2007
HISSIN50 said:
More info please.
Good luck.
it was like 70 degrees out today, it was a lot of idle-30 mph for like 5-10 min, then I looked and it was 210. By the way Hissin, I forgot to thank you for the last post about the e-fan, all I needed was power to the A/C wire. T-Stat is new, but you never know with those things so Ill change it.
HISSIN50
34
129
Jul 16, 2007
  • Jul 16, 2007
When it acts up (runs hot), does it sound and feel like the fan is on full-bore? It really feels like a fan issue.
Good luck.
conartist
77
Jul 16, 2007
  • Jul 16, 2007
As far a driving around, the deflector plays an important part in the cooling system.
gcwh02
515
pottstown, PA
Jul 16, 2007
  • Jul 16, 2007
Good luck.
Ill have to pop the hood when its acting up and see how high the fan is running, tryin that out now
gcwh02
515
pottstown, PA
Jul 16, 2007
#10
  • Jul 16, 2007
  • #10
haha headgasket is on right
gcwh02
515
pottstown, PA
Jul 16, 2007
#11
  • Jul 16, 2007
  • #11
ok, this is what I got. I start the car and the fan runs on low. I drove the car, the temps went back up to 210 and I popped my hood to find out my fan wasnt running at all. I turned the car off and my fan kicked on full blast for 15 seconds then shut off. Any suggestions?
HISSIN50
34
129
Jul 16, 2007
#12
  • Jul 16, 2007
  • #12
I had that feelin. When you say the fan 'was on low', do you mean that it started ramping up as you reached your target temp, or that you have an underdrive jumper and it came on? I have the feeling it has an underdrive jumper (I ask because I wanted to see if the controller had the fan come on because of temp, or because of a jumper).
Really go over that temp probe again. They can be kind of finicky (not nearly as bad as other brands though).
If it looks good, hit Brian's troubleshooting page. He has a bench test for the probe and some other stuff on there.
Good luck.
gcwh02
515
pottstown, PA
Jul 17, 2007
#13
  • Jul 17, 2007
  • #13
Good luck.
When it reached my target temp, the fan was not running at all.. I popped the hood at 210 degrees and put my hand in front of the fan and felt nothing. I quick turned the car off and the sucker kicks on full blast ( I do have it wired to kick on when cars off though). The only time my fan (that I seem to notice) runs is when I start it at idle (it will run on low speed). I checked out the page, nothing really to help me. Thanks, Greg
HISSIN50
34
129
Jul 17, 2007
#14
  • Jul 17, 2007
  • #14
At this point, I'd try to get ahold of Brian and have him tell you what it is. I believe I've seen someone with a real similar issue before but I certainly don't recall what the issue was.
In the meantime............
Did it pass the AC input test? It'd be cool to see that the fan comes on at 1/2 speed when the AC wire sees 12 volts.
You can disconnect the probe and look for 5 volts across pins 1 and 2. Was it there?
Good luck Greg.
gcwh02
515
pottstown, PA
Jul 17, 2007
#15
  • Jul 17, 2007
  • #15
Good luck Greg.
Thats what gets me confused, b/c when the AC wire sees 12 volts, my fan runs on low( I wouldnt say 1/2 speed b/c I dont think its that fast at idle). Ill try too look for 5 volts awhile between 1 and 2. Thanks again
gcwh02
515
pottstown, PA
Jul 19, 2007
#16
  • Jul 19, 2007
  • #16
New update, I do not have underdrive jumpers that came in my kit (what would they look like?) Also, I don't think it came with the fusible link either. Im not sure if any of this helps.
HISSIN50
34
129
Jul 19, 2007
#17
  • Jul 19, 2007
  • #17
If you think something is missing or got lost from the kit, I'd contact Brian. You should be able to use a substitute for the jumpers from Radio Shack, and you can get fusible links at the parts store. Talk to Brian.
Good luck.
Engine 1986 GT Overheating issues
  • 86 5O GT
  • Jan 25, 2026
Fox 5.0 Mustang Tech Jan 29, 2026
86 5O GT
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
