I have a 97 GT. I've always had problems overheating really since I've had it. Usually it was the water pump. My intake manifold started leaking cause the plastic corroded and that caused it to overheat. I replaced that with the manifold with the aluminum crossover and that stopped that problem. I let it idle for a while without the reservoir cap on to eliminate air in the system. I was monitoring it for a few days after that install and the cooling system was acting fine driving short distances. Never got out of normal temp range. However the cooling light was on the whole time. I started driving it as a daily driver and still it was cooling fine with the cooling light on still. Then a few days later it started overheating on the way back home. It never got to the red but I checked when I got home and coolant was boiling out the reservoir cap. Today I let it idle for about a half hour and and it got to normal temp range and stayed there. Fan turned on and off fine and no leaks anywhere that I could tell. The cooling system light was still on however. I do have a underdrive pulley on the water pump and a fan from a 3.8L stang. Could those be the problems? Or something else?
