overheating problems!
xYoung347x said:
the fan doesnt come on at ALL!
You just answered you own question. The radiator and water pump is not the issue. Test that fan out and make sure it comes on HIGH. The fan has a low and high side. The middle wire is a ground. Pull the connector and look inside the fan motor. If you see electrical damage then ditch the fan and replace.
