Overheating Problems
  • Thread starter Thread starter Madlx5.0
  • Start date Start date Apr 11, 2008
M
Madlx5.0
  • Apr 11, 2008
I converted a 4cyl mustang into 5.0 with rebuilt 302, about 2 years ago. Every since I got it running, it has been having overheating problems, mainly in spring and summer months. Happens while driving on highway and in slow moving traffic. I have replaced water pump, t-stat with 180, radiator cap with spring release, bought new 2 core radiator from o reilly back in 2005, flushed radiator out, replace hoses, installed proform 16 in electric fan, and burped cooling system. Timing is set at 10 degrees advanced before top dead center. No matter what I do, when the weather is above 70 degrees, temp gauge will go to 180, 210, 230, 250 while driving. Stays at 180-200 idleing in driveway. One thing I did notice after flushing, have brown liquid in radiator. I'm thinking my water jackets and engine block may have rust and corrosion. IS there anyway to clean block and water jackets, like at radiator shop or something performance shop can do .
Any advice or recommendations!!!!!!!!!!!
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Apr 11, 2008
  • Apr 11, 2008
Are you using the stock temp gage? If so, that's a big part of the problem; you don't know how hot it's actually getting.
93GTosu
183
  • Apr 11, 2008
is there an air deflector under the radiator? its a black piece of material that hangs down and helps to "deflect" air up into the radiator. Sometimes if you don't have this you can get trouble cooling while moving (which is what it seems like by your post)
what kind of "brown" was in the radiator? brown like oil? how's your oil look? head gasket failure?
just throwing ideas out there.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Apr 15, 2008
  • Apr 15, 2008
Could you have the wrong rotation water pump on the car?
Engine 1986 GT Overheating issues
  • 86 5O GT
  • Jan 25, 2026
Fox 5.0 Mustang Tech Jan 29, 2026
86 5O GT
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
M
1997 Mustang GT Overheating Issue
  • Mustang1988!!
  • Sep 3, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 24, 2025
squeak93
