overheating
  • Thread starter Thread starter fastdave
  • Start date Start date May 20, 2005
F
fastdave
144
Chandler,AZ
May 20, 2005
  • May 20, 2005
It is supposed to be 113* this Sunday here in Phoenix and already my car is hot. I have a 65 stang,289,195* thermostat, a 2 row Griffin rad,and a electric fan. It has always ran 195- 198 until I did a mod. I am installing an A/C. After I put on the condenser in front of the radiator it gets hot going down the highway. After I finish installing the A/C and turn it on I'm sure it will be way too hot. What do I do?? Install a 180* thermostat? Or maybe a new fiberglass apron that has the area where the license plate normally goes removed. Maybe that will provide me with the extra air flow I need. I already have in antifreeze,distilled water and Water Wetter. Please help me....
slepe67
78
  • May 20, 2005
I'd try a 180 thermostat, got one in my 67 in the nice muggy FL humidity, worked well.... Then, do you have a fan shroud? Also, why is the condensor in FRONT of the radiator? Try relocating it and see if it helps. Just suggestions.
65fastback2+2
1,229
Louisville, KY
May 21, 2005
  • May 21, 2005
A/c cars came factory with a 3 row rad, 4 row is better.
You prolly have a 4 blade fan right now...get a 6 or 7 from a big block mustang or thunderbird, DO NOT get some cheap flex fan, they are crap.
Run a fan shroud
Run a 180 degree t-stat
F
fastdave
144
Chandler,AZ
May 21, 2005
  • May 21, 2005
I did have a flex fan with a shroud that always worked great. I now have an electric fan from hot rod air. It has its own shroud. It cools great at stop and go traffic. The problem is when I am going down the highway. The A/C condenser was built to be located in front of the radiator like most of the cars are. I wish It could be located somewhere else. That would mean new hoses $$. But might not have any other choice. What do you guys think about the fiberglass apron w/ the large opening in front where the license plate normally is?
68keyblr
20+ Year Stangneter
Mar 17, 2003
946
20
49
Arizona
May 21, 2005
  • May 21, 2005
I live in AZ too, and did the Vintage Auto Air thing a few years ago. I installed a 4-row radiator when I installed the A/C, and it's never run cooler. I could idle in Hell forever with the A/C on and it would still run cool.
F
fastdave
144
Chandler,AZ
May 21, 2005
  • May 21, 2005
The clearance between my fan motor and water pump pulley is so close that it is tough to get my fan belt between the two when I put it on. My Griffin radiator is a 2 row but it cooled better than my stock 3 row standard radiator. I also e-mailed them to see how much the cooling difference would be between my 1" tubes and the 1.5" tubes and how much thicker that rad would be. I will have to resolve this one way or another even if I have to get a bigger radiator.
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
D
03 mustang Mach 1, 4.6L None Supercharge
  • DangStitches
  • May 18, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 23, 2025
Overheating
  • 4.6L not a five-o
  • Jan 21, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jan 30, 2025
4.6L not a five-o
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
