OverHEATTING need help
  • Thread starter Thread starter 5Liter1990
  • Start date Start date Aug 10, 2006
5Liter1990
Northport, Long Island
Aug 10, 2006
  • Aug 10, 2006
Hey guys...
Day two of my car overheatting and i cant figure out whats the problem when shes cold she doesn't draw from the overflow and she never has antifreeze/water in the radiator i cant any leaks anywhere everything is as tight as can be. Oil looks fine and im not getting white smoke out the exhaust. i feel like i can't put enough antifreeze/water in her. Once in a while if i release some "air" pressure from the radiator when shes hot she will draw from the overflow and be ok but not working anymore... Need help asap!! Thanks
Fett
766
  • Aug 10, 2006
Is your overflow tank overfilled? If you can't find any leaks, is it possible that your cap is allowing coolant to piss out the whole time? You figure a 16lb cap only opens at 16lbs of pressure...but if it is bad maybe it is allowing coolant out at a very low pressure.
I don't know...just a thought.
5Liter1990
Aug 10, 2006
  • Aug 10, 2006
Overflow tank is at best underfilled but always manages to fill up more and more, i just bought a new radiator cap thinking that might help something.... no dice the only thing i havent replaced is the thermostat, and i see no leaking or even spots where antifreeze was leaking before i opened the hood ex. while driving
Fett
766
  • Aug 10, 2006
Is your overflow tank broken/cracked?
When I removed mine last week I noticed it had a crack about half way down. It had been leaking coolant the whole time, but it was at such a pace where I didn't notice it.
5Liter1990
Aug 10, 2006
  • Aug 10, 2006
I dont think so but i cant see it being, the car looses coolant too quickly for it to be a slow leak
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Aug 11, 2006
  • Aug 11, 2006
You're gonna have to check everywhere with it idling at normal temp with a flashlight.
Sometimes you can have a leak coming from the a freezeplug on the back side of the motor and it will hit the exhaust. Do you smell antifreeze? Have you put more than 2-2 1/2 gallons in it? If so you have a leak.
Also check by the thermostat housing, the back of the intake. I've had leaks there before. The heater core is also a culprit sometimes
95cobraguy
637
11
Concord, NC by way of LI, NY
Aug 11, 2006
  • Aug 11, 2006
change your radiator cap.
Engine 1986 GT Overheating issues
  • 86 5O GT
  • Jan 25, 2026
Fox 5.0 Mustang Tech Jan 29, 2026
86 5O GT
Fox Help
  • 93fox85
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 23, 2026
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
JD1964
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
