overloading/runnin rich
nasty5pt0
hey guys, im new here but not to mustangs. Quick question... i put a 155lph in tank pump, 30lb injectors, gt40 upper and lower, 65mm tb w/ spacer and cold air intake... car flies, but since i put the injectors in (today) it was bogging out real bad at idle and running real rich.. smoking and everything..if i sit at a light for more than 20-30 secs it will die and wont stay running unless i keep pumping the gas... the fuel press regulator is plugged in, all vacuum lines are connected correctly and map sensor is plugged in.. any suggestions? my buddy suggested an after market fuel pressure regulator... i dont know... any help is greatly appreciated..thanks alot guys.
