oversized thrust bearing?
hungrymonkey
White by Birth, Trash By Choice
12
108
Oregon.
my machinist turned my crank to .020 on the mains and .010 over on the thrust. I cant find anywhere that can get them except for him, and he wants 70 bucks for the main bearings.
its pissing me off since It would of cost $80 for him to weld and regrind the thrust. now I am out the $25 that I payed for the original main bearings and now the $70 for the right bearings.
anyone know where I can get main bearings that are .010 over on the thrust? PAW cant and I am about to call summit to see. :mad:
If I understand you correctly, he should have took some off of all the main caps, bolted them back on, and align honed the block. You can probably order the odd sizwd bearings individually, but that is a pisspoor jov of machining for an engine. Maybe you should cut your losses and take it to a real shop.
If I understand you correctly, he should have took some off of all the main caps, bolted them back on, and align honed the block. You can probably order the odd sized bearings individually, but that is a pisspoor job of machining for an engine. Maybe you should cut your losses and take it to a real shop.
