P-51 + hood fitment
Ok I KNOW there has to be a thread on this somewhere, but for the life of me I can't find it. What hoods will clear a P-51? I know the stock is supposed to, but some instances it hasn't. This may be the case for me as well. Any ideas?
well i have seen only two p51s on stangs of my friends, one had a cobra r and it fit fine, and the other had a stock hood with the rail cut out and it rubbed. I think pretty much any slightly cowled aftermarket hood should work
2" should be more then enough clearance. The ones i've seen in person were just rubbing barely...so an inch would do it just fine. So the 2 " would be good. But i guess its better to install it then see what you need. Supposedly this intake does fit on some cars with no clearance issues. So everyones tolerances are different. Make sure you post pics...
