P/S headlight very dim 65/66 Stangs
Ok, I'm sure someone has had to have had this happened on your 65-66 Mustang. My ps headlight is not fully lighting, i pulled the light out and it worked fine on other side. Also the rt blinker light stays on now since headlight went screwy. It's not light and I can only guess maybe a grounding issue. Any help is most appreicated....
Definitely sounds like a ground. There's a ground wire that connects directly from the headlight socket to, I think, the radiator support just inboard of the headlight. Check the driver's side - you should be able to find it and confirm that the passenger's side one is loose or missing.
