P/S pump SCREAMS in the cold?
i figure its normal, but my power steering pump absolutely screams in the cold. at idle for warm up i can hear it, and often while driving i can hear it. it goes away after about a half of day of on and off driving. but it gets so bad that the car even threatens to stall sometimes when im turning.
But, once the pump warms up (only after alot of driving, if the motor is warm the PS pump isnt necessarily warm) it stops and steering become easier. is this normal? i want to run a new pump anyway as i hate the stock yellow one, but also b/c i need a new rack anyway. thanks alot guys.
What P/S fluid are you running? Your suposed to run Type F automatic transmission fluid.
If the fluid is bad or wrong, flush it. Best way to flush it would be to disconnect the return hose (rubber line, not threaded) and plug the bottom of the resivour, point the return hose into a bucket, have about 3-4 quarts of ATF F in a large container and as one person turns the wheel left and right full bank, to full bank pour it in. Do this with the front wheels off the ground and when you have it full again, turn it bank to bank and then full one way, shut off motor let it sit for about 15 minutes, then turn it the other way, let it sit for a while and then drive it.
You could also have a restriction in the line, or a bad pump. Fords are bad about their P/S pumps making noise.
I would try flushing it first, but if it persists, just buy a new one, Ford pumps are cheap. I usually use fluid for pumps with high mileage. That way it conditions the seals and lines.
