p060b, p2104, p2110 codes - in failsafe engine mode
JohnEP
'05 GT in failsafe engine mode and shows p060b, 02104, and p2110 codes even after replacing entire TB with sensors/motor, and replaced accelerator pedal. Good voltage at the sensors. Thinking that the PCM is toast and is the reason for mode and codes. Anyone have experience with this situation?
Did anybody ever resolve the " P060B, P2104, P2110 dilemma? Mine started after replacing the throttle body and pedal sensor. Mechanic said it was the PCM computer. The throttle body and pedal sensor were aftermarket. Have read that could be causing it. Mine is a 2008 Base Mustang with 133,000 ish miles on it. All stock except aftermarket sensors. Wanted input before replacing PCM
