So I bought a Moats Quarterhorse for my 03 Mach 1 and installed it. No problems. I had the ECU out of the kick panel area and it was just hanging out. Everything was working fine. I put some electrical tape over the J3 port where the QH was poking out to seal it off so no moisture would get in there. Everything was still fine and I drove the car like that for about a day. I decided to put the ECU back in the kick panel. I was super careful with the ECU and the USB cable that was poking out the top. I got it mounted back in the factory spot and put everything back together.
This is where my problems start. I started the car and backed it out of the garage. The motor was running rough, check engine light on, wouldn't hold idle and actually died. I got it to start again and pulled it back into the garage. I removed the QH unit, tried it again and the car still ran poorly. I disconnected the battery and let it sit for 5 minutes. I came back and started it up. Car ran fine, no problems at all. Drove it around the block, it was fine. Parked it. Started it again a few minutes later. MIL came on within 30 seconds of the motor running but the car ran fine. I parked the car last week and havn't been driving it. Picked up a code reader this morning and pulled a P1451. According to this:
http://www.obd-codes.com/trouble_codes/ford/p1451.php
It looks to be either the EVAP system or my ECU. I have tried to clear the code with my reader but it wont clear. I have checked fuses #2 and #8 under the dash and they are confirmed good with a DVMM. Now the car does have about 120,000 miles on it so the EVAP system could have a bad valve and if that is the only issue, I'll be happy but I don't think that is the case here.
Why would the EVAP valve cause my car to run like garbage from a cold start ? What I'm really worried about here is having a damaged ECU. The car does seem to run fine at the moment and I do want to be able to use my QH on it so I'm really stuck at the moment. Any help with the diagnosis would be much appreciated.
