Paint question
94pony
151
Arlington, Tx
I bought a toneau cover fot my convert. It has the ford gray currenly on it. Should I -
#1. Sand it down
or
#2. Use paint remover
Will the sandind job mess up the cover. I'm not sure it if is urithane or fiberglass. Its from classic concepts.
Thanks
I'm not really experienced with auto finishes, but I use to finish wood, lot of laquer spraying. So here's my crack at it..if the finish that is on there already is in good shape could you just clean it/scuff it up and spray your color/clear coat right over it? Unless it's a super tight fit, can't see the paint build-up being a problem...just my .02, good luck with it
95BLKGT5.0 said:
Sand it
Prime it
Paint it
The Gray is Gelcoat and needs to be sanded and then primed, sanded again,fill any pin holes, spray sealer, Then paint.
Don't skip any of the steps or you will regret it later.
Check out http://www.autobodystore.com
Go to there forum. They can answer any questions you have on paint.
Sounds like you know what you are doing. Hell I work at a body shop here in enid. And thats exactly how you do it. :nice:
