Painters I need advice
  • Thread starter Thread starter Bolt on 5.0
  • Start date Start date Aug 18, 2006
Bolt on 5.0
302
Suffolk, NY
Aug 18, 2006
  • Aug 18, 2006
I am going to clean my engine bay with some simple green but wanted to know before hand if it will leave a film. The reason I am asking is because I am going to paint the engine bay either this week end or next and was wondering if the simple green will effect it in any way. Thanks
Mustang78
486
Aberdeen, WA
Aug 18, 2006
  • Aug 18, 2006
test it in a small spot and find out..you can always remove the film in a small spot if there is any, i used to clean my R/C cars with simple green/water, then blow dry with an air compressor, spray WD-40 on plastic parts to keep em extra shiny..or in your case forget the WD
~Mark~
GearHd6
459
Ashford, CT
Aug 18, 2006
  • Aug 18, 2006
Do you want to know if the simple green will leave a film that will hinder the bonding of the paint you're going to be applying? If thats your question then yes it will hinder the adhesion of the new paint. After the simple green i'd really hose it down good and wipe it with a water wet rag. Then prior to painting it i'd wipe it down with some enamel reducer on some paper towels or something clean and lint free would be better.
Bolt on 5.0
302
Suffolk, NY
Aug 18, 2006
  • Aug 18, 2006
Ok that what I wanted to know, if it will effect the bonding of the paint. I think I will leave it be and sand a paint the new surface. Then Ill simple green everything.
GearHd6
459
Ashford, CT
Aug 18, 2006
  • Aug 18, 2006
I tend to have better luck cleaning things like engine compartments with Castrol Super Clean than Simple Green. Simple Green seems to leave a good film where the Super Clean seems to rinse away nice and do a much better job. The Super Clean is more potent so I tend to wet the areas with the hose first before I spray it on so it sort of dilutes it on the surface.
pb_paulie_b
894
Chaptico, Maryland
Aug 18, 2006
  • Aug 18, 2006
A power washer does a really nice job as well.
zookeeper
3,415
63
109
Rogue River, Oregon
Aug 18, 2006
  • Aug 18, 2006
I used some cheap ($9/gallon) lacquer thinner that I use to clean my gun to degrease and prep my engine bay. I just sprayed it from a squirt bottle and scrubbed it with some coarse steel wool pads. It worked like magic, even taking off the factory paint! For protection I wore a pair of heavy rubber gloves and a $20 respirator and it took less than a full day to get it ready to go.
O
One Owner
Quincy IL
Aug 18, 2006
  • Aug 18, 2006
I always do my last wash of the area with Dawn dishwash and a grey scotchbright. I always use adhesion promotor on the underside of hoods. No peeling or flaking paint on my cars, ever.
Dan
T
Fox Help Request: Clutch Cable Installation on T5 Swap — I Can’t Find the Mounting Hole
  • TDM389
  • Feb 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 19, 2026
nickyb
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Progress Thread 93 LX father son project
  • ZAM93LX
  • Oct 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 3, 2025
Scrapla347
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
