painting interior problems
  • Thread starter Thread starter billison
  • Start date Start date Oct 15, 2006
billison
I like tinted tail
2,607
1,094
184
stl
Oct 15, 2006
  • Oct 15, 2006
OK I'm painting my kick panels and a few other parts, anyway, i had painted them before with cheapo black spray paint and to night i was redoing them with dupli-color paint and it was good for the most part, BUT on one of the parts started to spider-web real bad and the paint just came off, what happened and what can i do to fix it, thanks
Glaze
133
Gainesville, GA
Oct 15, 2006
  • Oct 15, 2006
is the part plastic or metal? was it painted before with cheapo black spraypaint? If so than paint is incompatible with each other. In this case it must be stripped and properly cleaned and prepped. Id rather use the proper paint for plastics and vinyls available at 5.0 resto.
I have a whole black interior complete for hatchback 91-93 for sale in excellent condition. Its still in car. Pm if interested anyone.
larrendeuce
649
Southern NJ
Oct 15, 2006
  • Oct 15, 2006
Its possible the new paint you used was not compatable with the old paint. That caused the paint to become crazed. Sand the panels down if you can, if you can't because of texture use a scotchbrite pad and try to remove the high spots. Use a primer/sealer autozone usually offers it from duplicolor in a can. That will be a barrier between the two different paints and hold your finish. Also parts can never be too clean. Clean once, then again, and one more time to be sure. Paint won't stick to adhesive, wax, grease, or dirt. Get some good grease and wax remover and spray it on and wipe it off, using a rag soaked with it just smears the mess around instead of removing it.
billison
I like tinted tail
2,607
1,094
184
stl
Oct 15, 2006
  • Oct 15, 2006
yeah, i think i'm gonna have to compleatly strip them, prep and paint, sucks, but i'd rather do it right, thanks for the help guys
Georgie
455
Montreal, Canada
Oct 16, 2006
  • Oct 16, 2006
i painted my whole dash and ALL interior trim black! i also painted my complete floor pan.. the MOST important thing in having a successful paint job is PREPARATION. I used Isopropanol to clean off any grease or debris. Then don't touch anything with ur hands and begin painting. Don't forget the plastic should be tacky after cleaning!
billison
I like tinted tail
2,607
1,094
184
stl
Oct 16, 2006
  • Oct 16, 2006
yeah i took my time the first time around, but the second i was lazy, so today i'll get the cleaning stuff and do it again, the long way...
Georgie
455
Montreal, Canada
Oct 16, 2006
  • Oct 16, 2006
and dont forget to spray at least 8 inches away... plus if u heat up the can a little( leave them in the sun) + shake em 4 at least 2 mins, they should spray ALOT mor even;ly!
billison
I like tinted tail
2,607
1,094
184
stl
Oct 21, 2006
  • Oct 21, 2006
so i guess my being out in the cold is why the paint sprayed so crappy tonight?
billison
I like tinted tail
2,607
1,094
184
stl
Oct 21, 2006
  • Oct 21, 2006
ok, i put a coat of primer on them and it worked better than befor BUT it did it again in some spots and my thoughts were to get the aircraft remover stuff from walmart and strip them down and start over, or is there a better way to strip them, man i hate when i try to save money and end up spending more
Fett
766
#10
  • Oct 21, 2006
  • #10
For the plastic trim peices, such as dash, rear 1/4 panels, kick panels, and center console, use SEM vinyl dye. Clean all the panels with laquer thinner, or other paint stripper that will not melt the plastic. Let dry, start coating with SEM. That stuff kicks ass. It holds onto the hard plastic stuff like glue, no need for primer or clear coat. If you are doing your interior black, I would suggest getting SEMs Landau Black. It is most like stock, not glossy and not flat. Looks great.
For the scuff plates and door armrests, use sandable primer, semi-gloss trim paint, then semi-gloss clear coat. For some reason, SEM doesn't stick to those very well.
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Oct 21, 2006
#11
  • Oct 21, 2006
  • #11
Prep is everything with paint..you need to wash the parts repeatedly with dish soap, get your hands on some plastic prep spray and make sure to use a plastic paint/dye. You get out of it what you put in...half assed job will look like hell...if not right out of the gate, but soon after you touch it or clean it later. I put in the time with mine to prep it, sprayed it in 30 degree weather, and two yrs later the entire interior looks factory new.
larrendeuce
649
Southern NJ
Oct 22, 2006
#12
  • Oct 22, 2006
  • #12
Don't use regular aircraft stripper on plastic, it will ruin it. Make sure the label says safe for plastics. I remember seeing a product of the same brand that is safe.
billison
I like tinted tail
2,607
1,094
184
stl
Oct 22, 2006
#13
  • Oct 22, 2006
  • #13
where do i get the sem paints? and i skiped the aircraft remover, i got just good ol paint remover..
billison
I like tinted tail
2,607
1,094
184
stl
Oct 22, 2006
#14
  • Oct 22, 2006
  • #14
oh man have i learned my lession, i'll not skimp on the good stuff again. It took me like 2 hours to clean and strip the parts, everything whent fine till i got to the pillars, the stripper was a little stronger than the plastic, it started to bubble in a few spots, but i cought it befor it was bad, so i'll prep and paint them, and if they don't turn out i'll have to buy a new set and then prep and paint .pita
billison
I like tinted tail
2,607
1,094
184
stl
Oct 22, 2006
#15
  • Oct 22, 2006
  • #15
and what are scuff plates
Georgie
455
Montreal, Canada
Oct 23, 2006
#16
  • Oct 23, 2006
  • #16
i used the interior paint from Late model restoration! stock color, and was ****ing easy...like i said i painted the whole interior ov my vert with no problems... like ppl stated above, use a plastic degreaser, then paint, more than two coats is ideal..i didnt use any primer whatsoever... looks great, even my registers (vents) are perfect!!
but i know what u mean when u say it comesout ugly..i had that problem when i painted my floor pan...
Georgie
455
Montreal, Canada
Oct 23, 2006
#17
  • Oct 23, 2006
  • #17
scuf plates r the long plastic things that go along the edge of the door(floor) held in by 4 or 5 screws..i got the stainless scuff plates from late model restoration, they look freaking awsom!
Georgie
455
Montreal, Canada
Oct 23, 2006
#18
  • Oct 23, 2006
  • #18
ohh yeah..and ur spray can should ALWAYS be used in a vertical position for optimal spraying
billison
I like tinted tail
2,607
1,094
184
stl
Oct 23, 2006
#19
  • Oct 23, 2006
  • #19
ahh the sills
M
Matching paint for Ford UA
  • mnky99
  • Sep 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 14, 2025
mnky99
M
What's it Worth? 2000 GT
  • Mustang5L5
  • May 8, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jun 13, 2026
KRUISR
G
Dash, Kick & Quarter Panel Paint - 67 Coupe
  • GotMojo
  • Mar 12, 2025
1965 - 1973 Classic Mustangs -General/Talk- Mar 13, 2025
Paint and Body What to use to clean up/prep painted surfaces before painting
  • AnthonyA1234
  • Sep 27, 2024
Fox 5.0 Mustang Tech Sep 28, 2024
limp
Take a look at my rack!
  • bicknell
  • Sep 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2025
Willybill32
