Painting Over Serial Numbers Without Burying Them in Paint
mllud
32
Im going to be painting a three stage paint job. I have a 68 mustang with the serial numbers on the top of the fender skirts.
I buried them in primer and feather fill during the restoration process. I sanded them both back to metal and cleaned the numbers and letters out with a scribe. So the serial numbers are clean and easy to read with light primer over them.
My question is will the basecoat / intercoat clear and clear coat cover them back up and not be able to read them?
I would think they should show thru just like a defect does.
I think the reason I lost them before is from sanding the added layers of primer.
How well did your serial numbers show up after paint?
BC/CC or Three Stage paint jobs.
i usualy sand blast the engine compartment so the numbers are usualy very crisp .just a light coat of primer just enough to cover then black. they usualy show very well.a three stage paint may cover them again.
horse sence
I guess i will tape over them when I paint. Imgoing to try and paint the engine compaerment this weekend.
Year:81968
Plant:FDearborn, MI
Body Series:012 Door Hardtop
Engine:C289 2v V8
Unit:103109
Miscellaneous Vehicle Data
Body:65A2 Door Hardtop, Standard Interior
Color:TCandyapple Red
Trim:2DDark Red Crinkle Vinyl and Dark Red Kiwi Vinyl, Standard Interior
Date:25HAugust 25, 1967
D.S.O:55St. Louis
Axle:22.79:1, Conventional
Trans:WC4 Automatic
Mike
horse sence
I think a window with a gold stripe to frame it would work. I want them visable. I would think this problem would come up more with the high solid paints we use now. Unless mine were just not stamped hard enough.
The autoworker was getting tired at the end of the shift. Can you imagine stamping serial numbers all day. It may have been done in a punch press changing a number each hit.
Mike
horse sence
Mike
it was a hand held unit that slid over the apron , i have seen numbers punched in a stager because they didnt lock the number reel down
