first, do most rotors rust? I assume there are some stainless steel ones out there but, they must be expensive.
As far as I know there are three options: let them look ugly, zinc coating, or painting.
Does zinc coating look ugly yellow/gold?
Im thinking of using black high heat header paint. I have already started masking off the braking surfaces of one of the rotors. Im leaving the outer edge, inner hub, slots, and holes exposed to be painted. How bad would it be if a little overspray ended up on the braking surface and then would be transfered to the pad the first time the brakes are aplied? Not a big deal?
Is this the best option?
Thanks
Thanks
the paint was also not a gloss type finish (matte silver)
