Painting the upper intake?
  • Thread starter Thread starter Vaz88GT
  • Start date Start date Apr 26, 2012
Vaz88GT
264
27
38
Apr 26, 2012
  • Apr 26, 2012
I was wanting to know if it is possible to paint the intake manifold without taking it off the engine?
If i cover everything, and I only want to paint the part you can see will it work? In theory I think it would but ill let you people give me the answer!
Three50won
1,135
64
69
Apr 26, 2012
  • Apr 26, 2012
Take 2-5 minutes and just unbolt the upper...easy enough.
89lxsport50
550
Franklin Tennessee
Apr 26, 2012
  • Apr 26, 2012
It will look like total crap if you don't remove it, and prep it properly.
Admin Dude
Jan 4, 1985
43,590
21,751
234
Box behind Walmart
Apr 26, 2012
  • Apr 26, 2012
It'll look about the same as if you applied the same method to plainting the entire car.
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Apr 26, 2012
  • Apr 26, 2012
Seriously? Buy a new upper plenum gasket, remove the four screws holding the intake plaque on, remove the six bolts and go to town with it.
Vaz88GT
264
27
38
Apr 27, 2012
  • Apr 27, 2012
I doubt its as simple as that but ill give it a look over and attempt it.
Can I get a guide?
Admin Dude
Jan 4, 1985
43,590
21,751
234
Box behind Walmart
Apr 27, 2012
  • Apr 27, 2012
Can I get a guide?
Ummm... yeah. That's pretty much it. You have a few vac lines and you want to ensure that you don't over torque the thing and strip threads when you reinstall.
fiveohwblow
Official Member
2,169
145
155
Apr 27, 2012
  • Apr 27, 2012
Can I get a guide?
Noobz is just the one to guide it in
Admin Dude
Jan 4, 1985
43,590
21,751
234
Box behind Walmart
Apr 27, 2012
  • Apr 27, 2012
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Apr 27, 2012
#10
  • Apr 27, 2012
  • #10
Can I get a guide?
Okay, here's your guide.
Pull the rubber boot off the throttle body.
Carefully disconnect the throttle cable from the bottom of the throttle body.
Use small visegrips or some other clamps to block off the coolant lines going to the EGR spacer and disconnect them.
Remove the electrical connectors from the EGR valve and IACV.
Remove the vacuum lines from the EGR valve and the fittings on the bottom of the upper intake.
Remove the four screws holding the intake plate and set the plate aside.
Remove the six bolts holding the upper intake in place.
Lift the upper plenum off and set it on your work bench.
Prep it and paint it.
Allow paint to dry.
Reinstall in the reverse order you removed it.
For a first timer, the removal and reinstallation will probably take a total of 45 minutes. Those of us that have done it more than once can probably do it in 25 minutes or less.
Vaz88GT
264
27
38
Apr 27, 2012
#11
  • Apr 27, 2012
  • #11
Well i pulled my back out at work, was looking forward to messing with it tommarow. It doesnt sound too hard just a little ignorant on my part
90lxwhite
I'm kind of a She-Man
5 Year Member
Aug 25, 2011
3,310
374
134
Between the Red and Rio
Apr 30, 2012
#12
  • Apr 30, 2012
  • #12
I painted mine when I had to remove it to replace valve cover gaskets. Didn't really do any prep work just hit it with the high heat rattle can and it came out nice. But I did however touch it up some once it was back on and it was ok, just put covered up some stuff w card board that I didnt want sprayed. I didn't go crazy with it or anything though
stykthyn
5,232
2,652
223
gainesville
Apr 30, 2012
#13
  • Apr 30, 2012
  • #13
I like VHT hi temp paint. it actually seems to hold better to old finish. just make sure all the oil and grease is scrubbed off.
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Apr 30, 2012
#14
  • Apr 30, 2012
  • #14
I used duplicolor, came out well just gotta see how it'll stand up to time I suppose
Vaz88GT
264
27
38
Apr 30, 2012
#15
  • Apr 30, 2012
  • #15
Busy weekend ahead of me! Going to paint my gt body kit scarlet red, and paint that intake!
Also replace my fuel pump, fuel filter. New Coolant reservior/over drain ( whatever ) and mount in a new spot so my CAI will fit properly.
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
May 1, 2012
#16
  • May 1, 2012
  • #16
a little while back I bought a new reservoir and the damn cap never would close right, got it from latemodel. It's ok I guess cause its always empty
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
May 1, 2012
#17
  • May 1, 2012
  • #17
What color are you going w/ the intake? I did mine in black
Vaz88GT
264
27
38
May 1, 2012
#18
  • May 1, 2012
  • #18
Gray, and im outlining the square black, and the 5.0 Ford H.O. red
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
May 1, 2012
#19
  • May 1, 2012
  • #19
ya prob know but there are two long bolts under the 5.0 plate that need to be removed to get the intake out
Paint in engine bay questions
  • B0udreaux
  • Feb 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 27, 2026
AeroCoupe
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
A
Help ID - Turbo GT, SVO differences
  • aldoelmalo
  • Jun 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 2, 2026
aldoelmalo
A
Trick Flow Series R to Box R Upper Intake Road Block
  • Habu135
  • Mar 31, 2026
  • 2 3 4
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
Habu135
